NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Re: NEW Project 2 2004 Connect T200 LX (Pic Heavy)
Postby Hotwheels » Tue Jan 06, 2015 9:58 pm
paul2012 wrote:
I've contacted that seller in March this year reguarding that gearbox (yes it's been on ebay for 5 month now).
Checked part no I got from seller & comfirmed it's actually a 5sp - know wonder it's never sold :lol:
R3PA is a 90ps TDCI engine fitted to connects from 2006 onwards & were never equipped with 6sp boxes :(
In the meantime I've grabbed the 2011 Focus box so I can get on & fit engine etc, Once I get a 6sp box I will swap it over.
Would this fit onto a 2002 engine unit just a thought, another idea cheers.
Hotwheels
Postby Hotwheels » Wed Jan 07, 2015 1:00 am
paul2012 wrote:Before I refit dash assembly, Though I better check fitment for accelerator pedal.
Good job I did, typical another minor change in mountings on connects from 2006 onwards.
Does this need to be replaced or can the old one still be used cheers.
Something to work some magic on 8)
Also new pedal switches have arrived.
& fitted to their respected locations.
Hotwheels
Postby paul2012 » Wed Jan 07, 2015 2:24 am
Yes it would fit but your speedo will not work, as this box has no VSS (vehicle speed sensor). Gearbox is for connects from 2006-2013
NOTE:- That gearbox has been on ebay for over a year & is NOT a 6 speed gearbox :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Hotwheels » Thu Jan 22, 2015 6:43 pm
paul2012 wrote:Hopefully rear bumper will be ready to pick up tomorrow :D
Decided to order new trim for centre floor console.
This one is a Sport/Mid option from Ford - Part No F5076095
looks a lot better, instead of console being all one colour. According to label stuck to it - trim colour is Triton
What price is the part cheers.
Hotwheels
Postby Hotwheels » Thu Jan 22, 2015 6:57 pm
paul2012 wrote:Routed wiring for ext ambient air temp sensor through engine bay. - Sensor clips onto back off lower bumper reinforcement bar :wink:
Now it's working as it should do & get this message & chime when air temp is 4°C & below. Simply hit menu set/reset to clear message.
Yes ABS light is on, due to ABS pump not plugged in yet, I really need to fill tank with diesel :roll:
Just an idea on what it looks like in the dark - yes they all can be dimmed including stereo via dimmer control on headlamp switch :wink:
What colour bulbs would you recommend for the control layout as I have all the switches out of the centre console at the moment cheers.
Hotwheels
Postby Hotwheels » Thu Jan 22, 2015 7:11 pm
paul2012 wrote:Ford FX (LSRNS) navigational headunit arrived today & fitted it.
After programming it to connect with IDS it works perfectly :D
Sony gen 2 headunit has now been listed for sale here :arrow: viewforum.php?f=66
What price can you pick one up for and would it be compatible with a 2002 connect cheers.
Hotwheels
Postby paul2012 » Thu Jan 22, 2015 9:45 pm
I think it was around £30
Hotwheels wrote:What colour bulbs would you recommend for the control layout as I have all the switches out of the centre console at the moment cheers.
Choice is yours on that one. :wink:
paul2012
Postby paul2012 » Thu Jan 22, 2015 9:50 pm
Yes with 2009-2013 dash fitted
One here :arrow:http://www.ebay.co.uk/itm/FORD-FX-LS-RN ... 4632350e00
paul2012
Postby tony&kasia » Thu Jan 22, 2015 10:53 pm
A smart unit :)
I have never liked a sardine can with a bonnet, How can you possibly own the road
tony&kasia
Postby Hotwheels » Tue Feb 17, 2015 10:28 pm
paul2012 wrote:Old hand brake lever to be replaced is in wrong position
New one fitted
New parts to fit floor rear section of centre console
New column switch gear removed from 2010 connect along with steering column
Switch gear & steering column now fitted
New Focus mk3 leather steering wheel fitted.
Cant quite make the part number out and what part do I type in on Ebay as I need this to finish the centre console section cheers.
Hotwheels
Postby paul2012 » Tue Feb 17, 2015 11:43 pm
Ford Part No F5037268 8)
paul2012
Postby CRobinson450 » Sun Jul 12, 2015 11:22 pm
could you please tell me whats that wire for which as he tag on it with also the little crimp on it please ? which says GDB
CRobinson450
Postby paul2012 » Mon Jul 13, 2015 2:27 am
CRobinson450 wrote:Image
Welcome to the forum :D.
That wire is 12v+ Feed to glow plugs, as shown below.
paul2012
Postby Foss » Wed Aug 12, 2015 12:27 pm
Is there a frame of some sort that makes it fit on a pre 2009 Tourneo/Transit Connect? I`m not swapping my 2008 Tourneo Connect dash, so I`m just wondering what my options are? Currently have the 6000 CD fitted.
Foss
Postby paul2012 » Thu Aug 13, 2015 3:41 am
Welcome to the Forum :D
For 2006-2009 Connects. You require the earlier double din version shown below.
paul2012
