Fuel Pipe Connections Tddi Filter URGENT
Postby get connected » Wed May 15, 2013 10:12 pm
Hi All...
Call me stupid, had the pipes off the fuel filter on Monday, my filter is the one with the strange shaped connector and two nomal types... can anyone please advise as to which pipe of the two normal ones go where... one has a black tell tale clip on and the other a white clip... ?
TIA Dave
Keep a smile on your face at all times! The others think you know something that they don't !!!
get connected
Re: Fuel Pipe Connections Tddi Filter URGENT
Postby get connected » Wed May 15, 2013 10:34 pm
Just looked at a picture on Youtube http://www.youtube.com/watch?v=EZujXZSECyo ... mine looks right, think I got some air in there somewhere.. just cut out won't start.. refixed the pipes and diesel leak now clear, just need to spray some easy start in tomorrow and hopefully OK now... The reason I took the pipes off was to change the filter, I opened the box last and found the wrong filter inside!!!! :shock:
get connected
