performance exhaust system
Postby nyron gaf » Thu May 16, 2013 11:05 pm
Hi all, hope all is well, I found out this afternoon that my 08 connect exhaust has a break in it, at the rear box end ( the pipe that goes into the rear box). Was thinking to get a performance exhaust to replace it with, but not sure where to start, would be very grateful if anybody has any info on where I could purchase this from, or any links for this exhaust, best to regards nyron
nyron gaf
Re: performance exhaust system
Postby g-man » Thu May 16, 2013 11:23 pm
if you mean a s/steel jobby with a decat pipe and chrome tailpipe try powerflow or longlife 8)
g-man
Postby Pltcmn » Sun May 19, 2013 6:05 am
Hi mate ,, DON'T go for the decat pipe ,,, your van will fail the mot if it hasn't got a cat on it ,,, any vehicle manufactured with a cat on has to have a cat on when you take it for a mot .
Pltcmn
Postby g-man » Sun May 19, 2013 9:49 am
no ones had a failure yet...........only going to fail on smoke
g-man
Postby limitedblack » Sun May 19, 2013 10:18 am
g-man wrote:no ones had a failure yet...........only going to fail on smoke
Mot rules changed in April this year, has to be physically there, although emission test doesn't need it to pass, so there's no need for the cat to have the right bits inside it ;)
Happy Easter
limitedblack
Postby g-man » Sun May 19, 2013 10:29 am
like i said.....no fails yet......not tested on emissions,only on smoke,de-cat pipe could be replaced if needed or just knock the guts out of the original,been talked about enough on here :roll:
g-man
Postby limitedblack » Sun May 19, 2013 10:39 am
Just saying, those is the rules now, so if he's thinking of a decat then the rules have changed from last year. I think the mot guys just ignore it at the moment like your saying, but its a defo fail.
Happy Easter
limitedblack
Postby g-man » Sun May 19, 2013 12:09 pm
i'd be more concerned about all the undeclared modded vans with void insurance
g-man
Postby limitedblack » Sun May 19, 2013 12:25 pm
True
Happy Easter
limitedblack
Postby tipp3r » Sun May 19, 2013 12:46 pm
i took my connect for mot i said to tester dont rev to heavy just fitted new turbo ,,,,he gets the tester probe and blows down it van past emmmisoins test with flying coulours :wink: ,,,best one ive seen
tipp3r
