fuel pump removal
fuel pump removal
Postby steviek » Sat May 18, 2013 9:55 pm
just need some info on removing my vans fuel pump.I need to take it of to have it tested as I believe it is at fault for my injectors breaking down .I've got it stripped down to the cambelt all I need to no is when I undo the pump sprocket do I need to do anything with the timing chain ,like is there a locking tool to support the chain or can I just remove the pump and the chain stays in place,it is a 2005 1.8 tdci .
steviek
Re: fuel pump removal
Postby liteace » Sat May 18, 2013 11:47 pm
Ive just changed the pump on a TDDI, removed the pump and the chain sprocket stayed in place
liteace
Postby Pltcmn » Sun May 19, 2013 5:53 am
Chain stays in place mate ,,, good luck.
Pltcmn
