Harsh rattling noise when accelerating.
Re: Harsh rattling noise when accelerating.
Postby gt_addict » Sun May 11, 2014 8:43 pm
Glad it's sorted now mate.
gt_addict
Postby sym jack » Mon May 12, 2014 4:07 pm
Many thanks, I went to three garages around here and none of them had a clue they all thought it might be the gearbox.
I did an internet search for a ford specialist in Devon and for one near Brixham came up, they told me over the phone what it was, when it did it and also why (these engines have an imbalance between 1800 & 2000 rpm and it causes loose springs to vibrate). So hats off to them.
sym jack
Postby Andy bowhill » Tue Mar 01, 2016 10:19 am
Hi, loose springs where, in the clutch, cheers andy
Just had my gearbox, clutch and a worn near side driveshaft changed but still rattlesr
Andy bowhill
Postby trixyben » Wed Mar 02, 2016 2:16 pm
I have this annoying rattle/vibration on my 54 plate as well kicks in at about 1700rpm and goes exactly at 2000 rpm
Diff mechanics said exhaust/gearbox box mounts/drive shaft but has them all checked and they fine
Loose springs in the clutch i suppose would make more sense, what happens do these springs keep wearing and wearing until they fail?
My clutch is working perfect nice biting point no issues with it
trixyben
Postby Andy bowhill » Sat Mar 12, 2016 8:09 am
Found the vibration/ rattle, turned out to be rear gearbox mount (dog bone), I was told everything from gearbox , clutch, driveshaft, exhaust, turbo etc. This part cost approx £15, try it first, cheers Andy
Ps way it was found was it only made noise going forward not in reverse, this is because engine and gearbox kicks one way forward and opposite way in reverse, because of the way the mount failed it would rub metal to metal going forward, try it, hope this helps
Andy bowhill
Postby coys84 » Sat Mar 12, 2016 2:46 pm
I've the same noise 05 tddi. I can hear the rattle on idle also and goes when clutch pedal pressed so going to order new clutch kit. Can anyone recommend where to buy a new clutch kit.
coys84
cron
