Retrofit A/C to Connect tddi
Re: Retrofit A/C to Connect tddi
Postby rouleman » Sat Oct 26, 2013 1:05 pm
The inside job finished...all parts fit it again.Only the radio left. i will put for a while an oem cd6000. Next step remove front pump and fit the a/c condenser.
rouleman
Postby rouleman » Sat Oct 26, 2013 4:21 pm
oooops!!!
My cooler is small, the a/c condenser is long, i need another cooler... :x i didn't noticed...
the cooler, with fan off the engine...
some pics from a/c lines....
rouleman
Postby paul2012 » Sun Oct 27, 2013 12:18 am
Your doing a great job there. :D
Reguarding radiator, you will require one like this
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby rouleman » Sun Oct 27, 2013 11:21 am
Back in the game! ...8,5mm longer cooler found.
rouleman
Postby rouleman » Sun Oct 27, 2013 4:38 pm
Almost finished, only the electrical connections in the engine compartment left for tomorrow...
a/c compressor's bracket.
compressor installed.
the radiator with fan, only the small fan is missing for the moment.
the difference between two radiators, left side the long one 78,5mm (upper base) right side the small 70mm
check valve.
rouleman
Postby rouleman » Sun Oct 27, 2013 4:50 pm
oooops! again...result of larger radiator...:x
solution found, for the moment fit a hose from wv golf mk4!!
the mixture antifreeze is ready, 3lt G12 + 4,5lt water, for -24C, With good bleeding leftover 1,5lt
high pressure switch.
low pressure switch behind fuel filter.
rouleman
Postby g-man » Sun Oct 27, 2013 4:51 pm
u fitting the small fan?.....got both on mine
g-man
Postby rouleman » Sun Oct 27, 2013 5:00 pm
the air direction wings? are short, there is one hole to the right to move right plastic wing but this is will effect that the down plastic don't fit, i suppose must be other plastic for that bigger radiator...
also i need a new engine-auxiliary belt, cover, now with compressor installed, and a new longer belt.
rouleman
Postby rouleman » Sun Oct 27, 2013 5:05 pm
g-man wrote:u fitting the small fan?.....got both on mine
Yes i will, i need to find one, from there i found the all parts, he told me that someone took him without asked him, probably he sold it to someone...
rouleman
Postby liteace » Sun Oct 27, 2013 5:14 pm
Dont know if you have already changed\checked. I changed the belt tensioner pulley on mine because it was noisy, Im sure when I ordered it there was 2 different type's,
60mm for non aircon and a 90mm for aircon
liteace
Postby rouleman » Sun Oct 27, 2013 5:45 pm
with the parts he gave me a belt but is too large to fit, almost 1/3 bigger from that one i have now.
with the bigger tensioner pulley, (90mm) i don't see it to fit that belt he gave me, on tusday, i will go to ask if there is another belt for that with a/c
rouleman
Postby liteace » Sun Oct 27, 2013 5:53 pm
Sorry my mistake, its the idler pulley thats a different size, not the tensioner pulley
http://www.ebay.co.uk/itm/TRANSIT-CONNE ... 43c0397476
http://www.ebay.co.uk/itm/TRANSIT-CONNE ... 3a808acf79
also check you belt routing is correct
liteace
Postby rouleman » Sun Oct 27, 2013 6:19 pm
From powergrip catalog, i found that there are 2 pulleys, and 2 belt for non a/c and 2 belts for a/c, probably there is one and one belt for 60mm and 90mm pulley
rouleman
Postby rouleman » Mon Oct 28, 2013 2:05 pm
The End.!!!!!!!! :D
Today the instalation came to end, with the electrical part at the engine compartment, the only thing remains is to be filled it with refrigerant, i test it with low pressure switch shorted wires and the compressor clutch engaged normally,only when engine running...
last pics...
patch wires to the engine side,
a/c wot relay on 11 position fitted, also fuse 10A in 26 position, there was no wires or terminal on those positions
wires to the compressor's clutch
and.... :D
a BIG THANK again, to paul2012 for the electrical wiring diagrams......... :D
rouleman
Postby paul2012 » Mon Oct 28, 2013 4:11 pm
No problem m8 :wink:
You've done a brilliant job there :D
paul2012
Users browsing this forum: Majestic-12 [Bot], metalworker0
