paul2012 wrote:I assume your connect is a left hand drive
rouleman wrote:used wiring connectors removed from crashed mondeo mk3, i couldn't find new ones even to the ford dealer, for patch wires to ecu and a/c wot relay, because no wiring harness for A/C was available, only one wire was available, from a/c button to the connector that is on the left side.
new wiring on the connector to the engine side loom.
patch wires to the ecu multiconnector
liteace wrote:
Its nice to see work in progress that your actually doing yourself, well done its all looking good
