hi im matt im new to the forum, im after a bit of help with my transit connect 58 plate. shes developed a fault, for some reason the speedo has gone off, when i leave the van a day or two and then start it on tick over everything is ok mileage shows correctly and no lights on the dash, but as soon as i drive off, the odemeter goes blank with some line on the screen, speedo doesnt work, engine management light comes on, and also the light when you leave the handbrake on to. has anyone else experienced this,
iv plugged it in on my cheap eobd reader and it says there a abs fault which the abs light has been on for a while nowso presume its nothing to do with this fault. there are no other codes stored.
do you think the clock has broke?
