Graham Taylor wrote:Problem you have is weighing up the cost of putting your van right and what it'll cost to buy another with the same spec, condition etc and you may still be faced with the same problems in the near future.
gt_addict wrote:My clutch pedal doesn't return fully to the top either. Always hook my toe under and pull it the rest of the way. I've had a new clutch and slave cylinder and also changed the master cylinder but it's still the same. I think my mechanic said something about the vacuum pump or something. But it works ok with no problems so won't be changing that in a hurry as it sounds like lots of money lol.
gt_addict wrote:Where abouts is it? Any bleeding required? Much dismantling? Would that solve the saggy clutch pedal you reckon?
