Hi guys, I'm new to the forum and I'm looking for some technical advice please. I have a 2009 1.8 tdci connect, with a oil leak from the lower end of the plastic timing cover at the injection pump. I cleaned the engine and investigated leak, I found that the lower timing cover bolt was missing and that the leak appeared to be coming from the bolt hole. I replaced the bolt and cleaned off residue. I then ran the engine under load, only to find the leak had got worse. It only leaks under load and is fine at tick over. I've phoned the ford parts department and asked about seals or gaskets for this area, but the parts department weren't very helpful. I thought that I would ask the forum if there was anything common or anything I should look at? I did think it was the seal plate behind the injection pump pulley and I also considered the oil pump housing? But was unsure if this has a gasket or seal?
I would be very grateful for any help or advice please.
