Hello again, good people. Looking for a step by step "how to" and came across this on the web. Would someone kindly read through it and approve or correct as necessary please?
It's nearly impossible unless you have a good air compressor and a powerful 1/2" or larger drive impact gun.The reason is you have to remove the cv axle nut and axle out of the way before removing the bearing and hub.The axle nut requires a couple hundred foot pounds to remove.The procedure is:Jack vehicle safely off the ground,remove wheel and tire.Remove axle retaining nut.Remove balljoint nut and bolt,pry down on lower control arm,and disengage balljoint and lower arm from spindle.Now the axle can be released from the hub,but leave the other end of the axle in the trans,just set off to the side out of the way.At this point,there are two ways to change the bearing.The wheel bearing is a double roller,cartridge type with the hub containg the wheel studs,pressed into the bearing.Remove the entire spindle assembly from the suspension strut,OR leave the spindle attached to the strut,and remove the bearing and hub from the spindle.Some guys swear by taking the spindle to a press,and pressing the bearing assembly out with a bottle jack.I just use a bushing driver set,and ball peen hammer,and remove the hub from the bearing...then remove the snap ring retaing the bearing in the spindle,then drive the bearing out of the spindle with the hammer and drivers.There you have it.Reverse procedure for reassembly
