Hi Guys
I have a problem.
When I turn on the AC switch after about 10 secs I hear a ticking noise.... the clutch spins for 2 secs and then stops for a few.. it keeps doing this.
I topped/topping up the gas using Halford EZ topup with the hose that the psi guage. As the clutch kicks in the pressure drops and the rises when the clutch stops spinning.
There is no cold air coming from the vents at all.
What could be the problem?
Thanks in advanced.
