Mondeo mk4 1.8 TDCI 6 sp gearbox (
7G9R-7002-ZF)
This gearbox will bolt onto the connects engine, & driveshafts will fit.
But it's not a straight swap.
Both rear lower & top gearbox mount do not fit connects & Connect mounts don't fit 6sp gearbox. - So you will have to fabricated 2 new mounts.
Also longer gearshift cables are required along with gearshift assembly - These too require to be modified to fit connects.
