just picked up my connect van and i need to de restrict it from the 70mph its set at
i find it dangerous just need another 10mph to play with when you need it
whats the process for doing it on a 2011 90ps van
teldec wrote:sounds good can you remap it at the same time
what sort of cost will it be as its a 200 mile round trip, pm me if you prefer paul
thanks
teldec wrote:all done speed restriction removed by paul2012
thanks for doing it paul you certainly know your stuff
cheers
paul2012 wrote:Ford IDS is required, due to ECU needs re-programming.
I can do this for you.
Chawowa wrote:Hi Paul2012 I was wondering if you could contact me? I’ve just bought a Tourneo Connect and it seems to be restricted to 62mph. I don’t suppose you are able to remove the restriction? I would pm you but I can’t figure out how, sorry.
Emma
