Adam_84 wrote:So this is the state of my cambelt heard something rubbing a few days ago on the cambelt cover, bloody lucky I checked before it snapped. I had the alternator changed along with new timing belt am I right in thinking timing belt is same as cambelt?
Adam_84 wrote:Couldn't get the cover out managed to remove all the bolts but can't remove it, the recess for the rear screw seems to be wedging it in and with the engine mount tight up against it I couldn't get it off
Adam_84 wrote:Will give HiQ a call tomorrow and see what they say, after finding it I'm reluctant to drive it. Any advice on how to approach this with them as the way I see it it's nothing that I've done to cause the the belt to wear so much obviously there probably going to think I've done something to cause the problem
