by mishnish » Mon Sep 08, 2014 8:44 pm
Pretty easy, unless there is anything else wrong. I did mine in 30 mins, but I had recently replaced the cat so the bolts at that end were easy to get off and on again. I had mine up on wheel ramps, back end up in the air. I struggled a bit for space at the connection to the cat but it got done ok. I used a bit of wd40 to get the rubbers on. I had to replace one rubber as one was missing. A generic cheapie from halfords worked fine. Getting the old one off I actually just angle ground the holders off for speed.
