water pump replacement
Postby Custard Kid » Mon Sep 22, 2014 9:00 pm
hi all the van is booked into my good friend to do a complete service overhaul with timing belt but whilst we are there i am thinking about doing water pump, should i change it? engine has done 160k (57 plate 90PS tdci)
Custard Kid
Re: water pump replacement
Postby gt_addict » Mon Sep 22, 2014 9:25 pm
Might aswell. Timing belt has got to come off to get at it anyway.
gt_addict
Postby Custard Kid » Mon Sep 22, 2014 9:28 pm
thanks buddy
its getting new glow plugs, fuel filter, air filter, pollen filter, oil filter, oil, brake fluid change, timing belt and water pump
anything else you suggest?
Custard Kid
Postby gt_addict » Mon Sep 22, 2014 10:24 pm
Timing belt tensioner too. Should come as part of the kit. Might want to get the idler pulley aswell seeing as the belts coming off. The bearings can fail and make a rachet then you'd have to take the belt off again.
gt_addict
Postby Custard Kid » Tue Sep 23, 2014 9:43 pm
thanks i will add that to the list :)
Custard Kid
Postby paul2012 » Wed Sep 24, 2014 1:46 am
gt_addict wrote:Timing belt tensioner too. Should come as part of the kit. Might want to get the idler pulley aswell seeing as the belts coming off. The bearings can fail and make a rachet then you'd have to take the belt off again.
Aux drive belt tensioner pulley too :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
