So, I picked up my latest Connect about a month ago, and immediately went on holiday for 3 weeks or so, meaning that the van has hardly been used. In between faffing about trying to get it ready to be my replacement for my other Connect, I'm using it as much as possible while it's still under warranty, ideally trying to break things while someone else has to pick up the bills!
I thought I'd come up trumps today, taking it to a mates garage to get the oil and all filters changed, and it went into limp mode......plug the reader in, and it throws up a few codes, the likely culprit being air mass meter. Codes cleared, try and run it up the road to see what it does next, and it just dies at any application of the throttle. Unplug the AMM, and it drives ok. So, we pull out the offending article to see if cleaning it might work, and there's a tiny piece of leaf stuck in it. This is what you get when you change the air filter, and don't properly clean out the debris in the bottom of the air box. Remove leaf, normal service seems to be resumed.On a different note though, what a bitch to start after changing the fuel filter....had to remove the fuel cap, remove the supply pipe at the pump, and draw the diesel through with a separate pump after 10 mins of trying to get it to fire up on the starter!
Moral of the story......if you're a mechanical numpty, leave well alone. My fault, I thought even I couldn't cock up changing an air filter, my mistake!
