flashing glow plug light
Re: flashing glow plug light
Postby dsid85 » Sat Dec 13, 2014 5:55 pm
after 200 mile check the changed injector was fine so pump ok so they've put 2 more injectors in and they said it shud be fine £360 lighter fingers crossed.
dsid85
Postby dsid85 » Tue Dec 16, 2014 6:32 pm
Done 100 mile since the change seems rough untill engine warms up when your driving steady engine seems jumpy ?
dsid85
Postby dieselboy1978 » Tue Dec 16, 2014 7:38 pm
Where did you get them from?
Did they come with new codes?
Bank account emptied by
DELPHI
dieselboy1978
Postby dsid85 » Tue Dec 16, 2014 8:49 pm
Got injectors changed by surestart diesel specialists Doncaster if you've got your toe down it seems fine but steady driving its very noticeable till engine is warm they said they changed and recoded them. its sorted the glow light issue just lumpy when cold?
dsid85
Postby dieselboy1978 » Tue Dec 16, 2014 10:22 pm
Most problems with that is injectors to be honest bit you could try getting pcm updated and then recoding the injectors back in
DELPHI
dieselboy1978
Postby Graham Taylor » Tue Dec 16, 2014 11:11 pm
I bet the fourth one is about knackered too or one of the new ones is leaking.
Graham Taylor
Postby dsid85 » Thu Dec 18, 2014 2:17 pm
They were pretty confident that the 4th wouldn't need changing would that do it though with it running fine once warm?
I'm nipping it back 2moro there going to stick computer on to check it.
dsid85
Postby gt_addict » Thu Dec 18, 2014 2:34 pm
Personally I would've had all four done. Saves the hassle. Plus the responsibility is on them rather than them saying "oh it's the fourth one that's the problem".
gt_addict
Postby Graham Taylor » Thu Dec 18, 2014 3:29 pm
dsid85 wrote:They were pretty confident that the 4th wouldn't need changing would that do it though with it running fine once warm?
Classic injector issue. If three needed changing you can bet money the 4th will too ;-)
Graham Taylor
Postby dsid85 » Fri Dec 19, 2014 11:30 am
I left it to them that's what they recommended I thought it was odd that they didn't change the last 1 like
dsid85
Postby dsid85 » Fri Dec 19, 2014 3:43 pm
They did a return check on it and they said the injectors are working fine so I'm lost?
dsid85
Postby Graham Taylor » Fri Dec 19, 2014 6:14 pm
dsid85 wrote:They did a return check on it and they said the injectors are working fine so I'm lost?
Did they check the replaced ones as possibly one could be faulty
Graham Taylor
Postby dsid85 » Mon Dec 22, 2014 9:18 am
Yes they said all injectors are fine
dsid85
Postby dsid85 » Tue Dec 23, 2014 8:41 pm
this van doesent get any better still rough running until warm then now and again seems to lose power put your foot down and theres nothing there until you flick ignition off on while still moving? no lights come on or anything any ideas feels like ive bought a right lemon? :(
dsid85
Postby dieselboy1978 » Tue Dec 23, 2014 11:06 pm
I am still confident that its your injectors
I would say new reconditioned delphi units with brand new codes, a pcm update and a recode and a 20 mile run with a new fuel filter will probably cure it mate
DELPHI
dieselboy1978
