Lift off/acceleration clunk. NOT GEARBOX STABILIZER
Postby Blackers1982 » Thu Oct 23, 2014 2:53 pm
Hi,
2003 Ford Transit Connect LWB 1.8TDCi
Replaced the bottom gearbox stabilizer 3 months ago as it failed...snapped and it has just happened again.
Replacement on the way but is the problem further back up the drivetrain?
When driving the van has a delay/slight clunk with liftoff and acceleration.
Top engine mounts look good maybe a drive shaft, thrust bearing who knows.
Any ideas?
Thanks, Shaun.
Blackers1982
Re: Lift off/acceleration clunk. NOT GEARBOX STABILIZER
Postby dodgy01 » Thu Oct 23, 2014 3:57 pm
lower suspension arm rubber bushes?
dodgy01
Postby Blackers1982 » Fri Oct 24, 2014 9:36 am
Hi,
Not likely I think. Definitely feels like it's engine/trans related. Power through the pedal isn't quite right.
Had a look though and it's fine, thanks anyway.
Blackers1982
Postby bigjohnthomas » Fri Oct 24, 2014 10:57 am
have you checked the gearbox stabilizer :?:
hahahahaahhaha :lol: :lol: :lol: :lol:
:oops:
bigjohnthomas
Postby lightning » Fri Oct 24, 2014 10:04 pm
Loose subframe mounting bolts.
That was the cause of a similar fault on mine. Took three garages to find it.
lightning
Postby lightning » Thu Nov 06, 2014 2:22 pm
Did you fix it?
lightning
