Mattie77 wrote:I had the same thing on my 06 tdci although my glow plug light flashed and it went into limp mode turned out to be fuel pump had disintegrated and ruined the injectors, hopefully won't be the case with yours but when it happened to me I searched the web and it seems quiet common on the delphi equipped connects .
101geo wrote:Changed the cam sensor, no joy. A mate had a new crank sensor ready to fit into another connect so I "borrowed" that and still no joy.
Graham Taylor wrote:101geo wrote:Changed the cam sensor, no joy. A mate had a new crank sensor ready to fit into another connect so I "borrowed" that and still no joy.
Not looking so good then! Check the pump for swarf, if you find any then pumps gone and will probably have knackered the injectors too
gt_addict wrote:What about the sensor on the side of the spider thing (fuel rail) on the front of the engine?
