walt1984 wrote:I don't have a clue but you can see if there's any fault codes. You can read them via the mileage display. If u search on here or you tube it should show u how to do it.
gt_addict wrote:So is it turning over but just won't catch?
gt_addict wrote:Is your van a TDDI or TDCI?
The only things I can think of are crank and camshaft sensors that couldve gone. But they are more of a degenerative thing, they don't tend to just fail. Unless the wires/connections have been knocked.
sam400 wrote:walt1984 wrote:I don't have a clue but you can see if there's any fault codes. You can read them via the mileage display. If u search on here or you tube it should show u how to do it.
Thanks but think that's only on the newer ones, mines a 51 plate
Cheersgt_addict wrote:So is it turning over but just won't catch?
Yea turning over a good un, just won't even try!
walt1984 wrote:51 plate. That must be one of the 1st connects.
gt_addict wrote:That only brings up DTCs for the instrument cluster, not the the engine unfortunately.
g-man wrote:walt1984 wrote:51 plate. That must be one of the 1st connects.
not bad for saying they started on a '52 plate
walt1984 wrote:Have u tried a sniff of easy start or hair spray to see if it will start on that then if it will run on its own. I know u said there is fuel at injectors but is there enough. Is it possible u have sucked some muck up and choked filter.
