Connect not starting,
Re: Connect not starting,
Postby gt_addict » Sun Nov 30, 2014 4:46 pm
Halfords fuel filter? You're brave!
Wouldn't trust one of those myself. Especially with the most expensive system to repair on the engine.
gt_addict
Postby sam400 » Sun Nov 30, 2014 11:52 pm
gt_addict wrote:<a href="http://www.halfords.com/" class="skimwords-link" target="_blank" data-skimwords-id="408678" data-skimlinks-editor="0" data-skimwords-word="halfords" data-group-id="0" data-skim-creative="300001" data-skim-product="408678" title="" occurrence="1" data-skim-node-id="35:Halfordsfuelfilter?Y_2" style="">Halfords</a><span style="position: absolute;"></span><span style="position: absolute;"></span> fuel filter? You're brave!
They gave me the wrong one anyway! Lol useless!
I ve found the problem I ve got water in the tank no wonder it doesn't start! Going to take tank off get rid of fuel clean it out, blast fuel lines with air, new fuel filter then try again!
Cheers
sam400
Postby Marty.H » Mon Dec 01, 2014 2:11 am
You buy diesel in cans by any chance as that's the only time I have seen a lot of water end up in a tank
Marty.H
Postby gt_addict » Mon Dec 01, 2014 9:27 am
I've heard from family members having water in the diesel and petrol when they purchased it from a local supermarket.
gt_addict
Postby Graham Taylor » Mon Dec 01, 2014 10:37 am
sam400 wrote:Thanks you make a good point about the diesel filter could have sucked some crap up when I ran out!
I ve just bought one from halfrauds going to put it on in a minute.
Cheers
Dont know what make you bought but Connects dont like cheap filters.
Graham Taylor
Postby sam400 » Tue Dec 09, 2014 8:39 pm
Still having trouble,
I ve cleaned tank, lines and fitted a new filter, had a nightmare bleeding it but think I am there now, got diesel coming out the injectors all though doesnt seem to be very high pressure' only squirts a few inches?
Any way bloody thing still not starting, I ve pulled the codes and have:
P1563 injection pump control module requesting stop
P1664 injection pump control module malfunction
P0216 injector/injection timing control circuit
Have I got these codes because of the messing around cranking/bleeding etc or is the pump knackered or something?
I ve got the cam belt cover of so I can check the pump timing, was worried it might have jumped a tooth or something, however belt and tensioner look in good condition.
There is a mark on the cam pulley and on the pump pulley but can't work out what they line up with.
Can someone help me with this?
Thanks in advance?
sam400
Postby f74nk0 » Tue Dec 09, 2014 9:38 pm
They don't line up with nothing you need timing kit
f74nk0
Postby sam400 » Wed Dec 10, 2014 12:22 am
Ok thanks looks like the P0216 was in reference to the timing solenoid in the pump, I think my pump is knackered can anyone help me confirm?
sam400
Postby paul2012 » Wed Dec 10, 2014 12:34 am
Are common for faulty fuel pumps - EDC bolted to top of pump has failed :(
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby sam400 » Wed Dec 10, 2014 9:23 am
paul2012 wrote:P1563 injection pump control module requesting stop
Thanks Paul, where is the best place to buy one? Shall I change the whole pump or just the EDC?
Sam
sam400
Postby sam400 » Thu Dec 11, 2014 11:09 am
Injection pump removed and sent off to peter remmington for diagnosis,
sam400
Postby sam400 » Mon Dec 15, 2014 10:13 pm
Results are back the pump is knackered and it's unrepairable, bugger.
sam400
Postby dieselboy1978 » Tue Dec 16, 2014 10:24 pm
No such thing as unrepairable.
Ecu for pump are available as are all parts
Bank account emptied by
DELPHI
dieselboy1978
Postby Graham Taylor » Wed Dec 17, 2014 10:44 am
sam400 wrote:Results are back the pump is knackered and it's unrepairable, bugger.
Send it to dieselboy ;-)
Graham Taylor
Postby Boyrevel » Sun Jul 08, 2018 10:15 pm
I’ve got issues with my connect and my mechanic has told me the fuel pump needs changing.
How much is a refurb dieselboy?
Boyrevel
