by VandanDave » Tue Dec 09, 2014 3:56 am
Hi
I replaced the aux belt tensioner on my tddi (enduraDi) From what I can remember, I never disconnected anything totally.
(apart from the intercooler pipe) I undid the expansion tank, fuel filter and power-steering bottle from their mounts and moved them aside. Once the power-steering pump is undone it can be moved aside enough without disconnecting any pipework.
The tensioner is then held on with 15mm nuts. I managed to undo these with just a 15mm spanner, but would seriously recommend getting a deep socket or box spanner, this will take a lot of effing & jeffing out of the job.
You could try starting the engine without the aux belt on. if you can still hear the squeaking noise, then you can eliminate everything driven by it.
You may of done the job by now, If so, did you cure the squeak and would the above been of any use. It may help other people who read the thread.
Cheers
Dave
