Got an 07 connect with 97k on it. had it from new. it was 75hp but has had the ecu remapped.
starts fine above freezing but get the ambient down to zero or below and thats where the fun starts. the engine will start with a fair bit of cranking, but immediatly cuts out and your back to cranking before it does it again. easystart stops it firing at all! if your lucky it will just about catch on, eventually. (If the battery still has enough left in it) It is definately ambient temp related. If you give up with it and the temp during the day gets above freezing, it will start straight away.
