g-man wrote:so long as they're weight rated it don't matter.....yours will be 95
highroof wrote:g-man wrote:so long as they're weight rated it don't matter.....yours will be 95
Well, if you're bothered about being able to drive quickly in the wet, I'd dispute that, there's no way a Hankook shod van would grip the way the Michelins do. 95T is recommended on a T230 LWB, but not a legal requirement. Any MOT tester will confirm this, because it's only a class 4 vehicle, and therefore not subject to the same degree of inspection as class 5 and above with regard to tyre ratings. As I found out to my cost, late last year! You can, for example, fit 91T rated tyres, and still be legal, providing the van isn't loaded beyond the weight permitted for that particular tyre.
g-man wrote:fit what u like pal for me....i could'nt give a toss
ake wrote:highroof wrote:g-man wrote:so long as they're weight rated it don't matter.....yours will be 95
Tyres must meet or exceed maximum axle weights. You can't base it on actual weight of van.
Good luck arguing with your insurer in the event of a claim.
Oh and I've ran Hancooks for years, with no grip problems in the wet.
kaibart wrote:Hi I have recently changed 2 front tyres on my van, I bought michilen Effeictive Grip as i've had 3 lwb hi roof connects and they definatly last very well and handle good too had Kelber tyre fitted by main dealer before I bought the van what a load of crap didnt last well at all, hope this helps
Punto443 wrote:I thought all the corgi vans had solid plastic wheels
