highroof wrote:Cheers, as in the one on the black block? I'm on good terms with the dealer, been in this morning and got every part that's likely to be the problem, on the understanding they'll have back what I don't use, so all the bits are here, including those seals, injector seals, and the pipework, etc. Just needed a heads up on what's likely, if it's only a seal, that would be nice!
teldec wrote:mine did this about 2 months ago mate and it was just the o ring on the first injector.
the pipe showing above is about 80-00 quid
blue estate wrote:what no injector ?
teldec wrote:honestly mate mine looked the same as that, thought it was a split leak back pipe but it was just one o ring and a new spring clip on the first injector
