nokivasara wrote:Is it a common issue with a standard 6000CD radio that doesn't keep up the set date when the van is not used?
If I drive it every day the date changes every day but if I let the van sit a day or two the date shown is the date I last used it
The clock and set radio stations work fine so I don't think it's a memory feed issue.
It's a known fault ..... mine is the same after an elapsed time of 3 days or so without use, but I live with it.
There's a fix to the ECU, but when clearing one bug you sometimes inherit others. From memory I think Paul2012 posted the technical bulletin fault no., but be aware that there's always a risk in any software update.
2007 T230LX LWB (110PS) with aircon.
Vans are designed for people with imagination. Cars are so limiting ... what can you do with them?
