Having reached my wits end I have joined the forum with hope of shedding some light on my charging problem.
A few weeks back the battery light on the dash reared its head on the way home one evening, lights dimming and heater slowing.
First thought, alternator.
Next day i whipped this off and had it tested at a local refurb center who stated it was in good working order. I replaced it and fitted a fresh belt while I was down there.
The problem still remained and a bit of Googling brought up the smart charge cable problem.
It looked tatty so I nipped to Ford and got a fresh one and also replaced the battery for the Silver Calcium type since I noticed this was running an incorrect lead-acid.
5 mins later the battery light is back on.
I have cleaned all connections and run diagnostics bringing up codes p0622 p1632 indicating alternator/smart charge problems... no sh*t Sherlock.
Running out of ideas and open to suggestions from the more experienced members
