Piglet wrote:Is that sort of misalignment even possible?
I recently fitted a new dogbone and the van is substantially better to drive, well worth the £13
gt_addict wrote:If the sound is a rattle or vibration type sound and it's only between that range of revs then it's more than likely "gearbox thrash". Common problem on the connect. The friction plate springs become loose and vibrate. Only cure is a new clutch set.
If the gearbox mount is worn just replace it as if left too long and you get a clunk when letting off the gas then the bolt will bend and you have to get a grinder on it to remove it.
tez wrote:Piglet wrote:Is that sort of misalignment even possible?
not last long for 13 pound I bet a few moths or weeks
gt_addict wrote:
How many miles has the van done? Do you know when the clutch was last changed?
