Wayneash12 wrote:Don't know if any one can help I've brought a KKDA engine 115bhp from a 2008 focus
I've brought a ecu key and transponder that all match but not from the same car as engine I know I need to get injectors coded but someone's told me I have to have the clocks coded as well is this truth
Wayneash12 wrote:Auto electrician said it had no codes wats so ever told me starter motor was sh*t so I got a new one the other day
Hand pumped two cans of Diesel out of it before I got all the air out of fuel System ( crankshaft sensor I have not checked as it was all ready on engine will try that tomorrow you have to have the engine set at tdc when doing crankshaft sensor don't you
