I have a 2003 connect i recently bought , its not the tdci version .
Its 2003 but has the older style mechanical pump and the old style injectors , i have no idea what this system is called ive always worked on common rail systems .
Anyway , it broke down on the way back from buying the van , the AA man suggest it was low fuel pressure .
So this mourning i have changed the fuel filter and im now getting good clean fuel through and into the filter , engine will still not start, i opened each and closed each injector and fuel is being released .
So im at a loss on how to diagnose from here .
I think its either fuel pump or injectors , i once read about a solenoid on these type of pumps that is used to turn the fuel on and off , could these be a good place to start .
to be honest im not used to working on this type of system and not know much about them does not help .
So being mechanical it can only really be fuel pump , fuel injectors and compression ?
