1k revs to 2k revs rattle
Postby Martyn84 » Mon Apr 27, 2015 8:38 pm
When driving in 1k-2k rev range the van makes a rattle noise. Like their is a hole in the exhaust. After that rev range. All is good. Ive read alot and found the term "gearbox thrash". When i put my clutch in. The noise goes Really annoying Does this sound like "gearbox thrash". If so whats next
Thanks. Van is a 2003 1.8 tddi
Martyn84
Re: 1k revs to 2k revs rattle
Postby liteace » Mon Apr 27, 2015 8:45 pm
A new clutch will sort that, I had the same, when I changed the engine I put a new clutch in and the noise was gone, the old clutch wasnt that worn BUT the center splines on the clutch disc where the gearbox primary shaft goes in was rattling about
Mine was real bad, when driving up narrow streets I had people turning round with a WTF's that noise look on their face, if you can put up with it leave it till its clutch change time
liteace
Postby Martyn84 » Mon Apr 27, 2015 9:00 pm
What if its not the clutch and is the gearbox? I get it changed and it still does the noise then its out with them both again and gearbox time. What would you do fit a gearbox aswel as a clutch. Or are you adamant its the clutch? Thanks for your reply mate
Martyn84
Postby gt_addict » Mon Apr 27, 2015 9:02 pm
I had a gearbox and clutch changed at the same time (synchro on fourth was shot), my friction plate springs were really loose which is what was causing the rattling sound on my van at about 1.5k-2k rpm.
gt_addict
Postby Martyn84 » Mon Apr 27, 2015 9:10 pm
Ok thats what ill do my mate has said he will fit both box and clutch for £80 My next question is what clutch i need to buy
Cheers
Martyn84
Postby Spike2450 » Mon Apr 27, 2015 11:52 pm
3 part LUK clutch. About £190 from the motor factors. + transmission oil.
95 plate 110 Transit connect lwb 87,000 miles
Spike2450
Postby Martyn84 » Thu Apr 30, 2015 10:45 pm
Just a quick one. Will a gearbox from a 2003 FORD FOCUS ESTATE 1.8 TDCI DIESEL 115PS 1998 - 2004 fit my transit connect 1.8 tddi 2003 ? Thanks
Martyn84
Postby liteace » Thu Apr 30, 2015 10:58 pm
Yes it will fit but different final drive ratio, the Focus box has 3.41, the Connect box has 4.06
liteace
Postby gt_addict » Thu Apr 30, 2015 11:02 pm
I wouldn't put that box in a 75ps tddi. Hasn't got the guts.
gt_addict
Postby Martyn84 » Thu Apr 30, 2015 11:03 pm
Sorry to sound thick. But is that good or bad. And will i need anything else for it to fit. Or is it a straight swop. Thanks for your reply mate
Martyn84
Postby Martyn84 » Thu Apr 30, 2015 11:05 pm
gt_addict wrote:I wouldn't put that box in a 75ps tddi. Hasn't got the guts.
how do you mean?
Martyn84
Postby liteace » Thu Apr 30, 2015 11:05 pm
You'd have to swap the gear selector on the top of the box
The Focus g\box has higher \ longer gears, where before you could do say 60mph in 5th, you'd have to go down to 4th as the Connect engine hasnt got the power to pull the van along in higher gears at the lower revs
liteace
Postby gt_addict » Thu Apr 30, 2015 11:08 pm
If you are going to carry any sort of weight then the engine won't have enough power to be able to move the van. Well it will but it would be putting it under a lot of load. Personally I'd just swap it for a box from another van.
But if you can is a personal can, not used for lugging about loads of tools or materials then shouldn't be too bad if imagine.
gt_addict
Postby Martyn84 » Thu Apr 30, 2015 11:09 pm
Ah right. So really i need one from the same engine /power
Martyn84
Postby gt_addict » Fri May 01, 2015 9:05 am
Personally I'd stick with what it has, they are the same on the 75ps tddi and the 90ps tdci as far as I'm aware. If you had a 90ps engine then it would be more feasible. I'm not saying it's not possible but for all the hassle of changing it you could lose driveability if it's used for work purposes. It's all down to what you need the van for really.
gt_addict
