I have a 90 ps Connect 1.8 TDCi 2005 with 225 000 km (about 140 000 miles). The engine is running pretty well, but there's vibration between 1250 ... 1500 rpm when I push the gas pedal on neutral gear. I can also hear a ticking sound from the engine. Just like one or two valve's clearances were wrong.
There's no smoking at all and it fires up every time at first start. When the outside temprature is cold, engine runs a few seconds with only three cylinders, so the glow pins should be renewed but after that no pboblems. Is it possible that glow pins may cause vibrating engine running and ticking sound to the engine? I also should renew my clutch as it rattles a lot below 2000 rpm. When I press the clutch, ticking also gets a little stronger. So now I don't know where to start to find out where's this ticking and vibration coming from. I have noticed that ticking and vibration are in sync, so the engine vibrates the whole van at same frequency with ticking. There's also a notice in my service book that cam belt has been renewed just before I bought the van and it has been driven about 8000 miles after that. Could this vibration and ticking be a problem with camshaft timing as well?
I have driven about 6000 miles after oil change but haven't noticed any oil or water loss during this period. If anyone has solved this kind of problem some advice would be appreciated.
