Hi guys,
I'm just getting some info together before I get round to fitting an inline coolant heater. (3 glow plug type). I know some came fitted with one and it was mounted on the bulkhead, but that's not really accessible seeing as I'm doing the work on the driveway.
There is only three hoses from the resovoir, two small ones at the top about 15mm diameter and one out the bottom that feeds to the radiator that's about 25mm in diameter. Does the coolant flow out from the bottom hose? If so why does it flow straight through the radiator?
I'm basically trying to find the best location for it so I get some heat through the heaters and engine as quickly as possible to aid clearing the windscreen and warm the engine to save fuel in the winter.
Any help would be appreciated. Oh the connections on the heater I'm getting are approx 25-28mm so ideally a hose that big would be beneficial so I don't interrupt the flow too much by adding reducers.
Thanks.
