For Finland (LHD) Longest shaft with bearing would be Passenger side & Short shaft drivers side
Yep, so when I order "off/side" I get the longer one which I need. Can you tell me what those "off/side" and "near/side" stand for?
gt_addict wrote:Near side is the side nearest the kerb/pavement (UK side of the road though), offside is the side furthest away from the kerb.
But your engine will be the same way as ours so when ordering from the UK it should be applicable.
jansu83 wrote:Got the longer one from J&R and fitted it today. No more shaking when I accelerate. And have to say it was surprisingly good quality for that price! CV boots seems to be very good rubber and nothing bad to say about the rest either. Even the support bearing felt and looked good. And one good thing is that the inner joint is completely round from outside so I believe the boot will keep the grease inside well.
Thanks to you guys, I got the whole driveshaft for the price that my local dealer is selling only the support bearing Hope it last for a couple of years now.
karl mcghee wrote:2 years warrenty
karl mcghee wrote:front wheel bearing hum very loud mate turn one way it stops straighten its back turn another way it stops etc
are you sure this isnt a gearbox fault ?
matt1987 wrote:Have you checked top gearbox mount
He had the symptoms of harsh gear change knocking noises when accelerating and gear stick moving when acceleratin and letting off. Yours may be similar.
