wipers wont turn off
Postby gismobri » Wed Sep 30, 2015 10:08 am
Hi I have a 2010 tourneo connect and the front wipers are on permanently and the washers and rear wash/wipe doesn't work anymore,any ideas whats wrong?
gismobri
Re: wipers wont turn off
Postby loot » Wed Sep 30, 2015 3:47 pm
Can you unplug the wiper stalk and it stops?
Ids map here
loot
Postby gismobri » Wed Sep 30, 2015 6:01 pm
I haven't tried yet but it stops when I pull the fuse out I have been told it could be the instrument cluster but that's expensive
gismobri
Postby gt_addict » Wed Sep 30, 2015 6:41 pm
Have you auto windscreen wipers?
gt_addict
Postby gismobri » Wed Sep 30, 2015 7:55 pm
Yes but on permanently
gismobri
Postby gt_addict » Wed Sep 30, 2015 8:57 pm
Is there some crap over the sensor (wherever that may be)?
gt_addict
Postby gismobri » Wed Sep 30, 2015 11:36 pm
No it's clean
gismobri
Postby loot » Wed Sep 30, 2015 11:38 pm
The rain sensor only turns the wiper on in the intermittent position, your wipers should be off at zero i think
Ids map here
loot
Postby gismobri » Wed Sep 30, 2015 11:44 pm
The wipers are on in every position
gismobri
Postby paul2012 » Thu Oct 01, 2015 11:09 am
Wipers on 2009-2013 Connects are controlled via GEM module :!:
Get DTC's (error codes) read.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby loot » Thu Oct 01, 2015 4:50 pm
I suggest unplugging the wiper motor and metering the contacts for shorts then check the connector for power.
Unplug the wiper stalk also.
You need to find out if something is shorting at the input and output as above, finally you'll be looking at the gem for faults :-(
Ids map here
loot
Postby gismobri » Sun Oct 11, 2015 11:02 am
System Codes Description Status
GEM B1319-60 Drivers door ajar circuit failure CMDTCs
GEM B1327-60 Passenger's Door Ajar Circuit Failure CMDTCs
GEM B1335-60 Door ajar circuit failure (right rear) CMDTCs
GEM B1571-60 Left Rear Door Ajar Circuit Failure CMDTCs
GEM B1611-60 Rear wiper mode select switch circuit failure CMDTCs
GEM B2115-60 Rear washer switch input short to ground CMDTCs
gismobri
Postby gismobri » Tue Nov 10, 2015 10:04 pm
Any ideas how I can fix these faults or do I need to replace gem
gismobri
Postby Punto443 » Tue Nov 10, 2015 10:52 pm
I'd be checking all earth leads for corrosion, especially the main engine to chassis.
This sounds not to dissimilar the probs that airthies had on his mk7, due to high current leaking through other systems. :?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby gismobri » Sun Nov 29, 2015 1:53 pm
The earth cables are ok but the fuse f180 is blown and keeps blowing when I put a new fuse in
gismobri
