ipbr21054 wrote:Hi,
I did read a few but i didnt see that one.
Looking on that page and entering my vin there is no mention of Central Locking.
As its dark now i wont be able to check the box under the dash.
Having said that looking on that well known site i do see a box with the detailed shown below.
2T1T-15K600-BD
It also has the markings CL DL RC
I am not sure if my connect has an alarm,so would this box be suitable, i mean is there such a box as CL RL AS ?
ipbr21054 wrote:Today i have looked behind the panel in N/S & O/S footwell but see no box.
I did notice that this connect has wind up windows if that makes a difference ?
m16uel wrote:i only took the glove box out for more light but you access it from under the dash it is hidden well, i didn't disconnect my battery because i don't have my radio code i just unplugged the both plugs and tested them in the box and the locking made a noise straight away so i done the programming and was fully working within 2 minutes I'm yet to remove the old box and pop the new one in place just held in by 2 bolts
ipbr21054 wrote:Hi,
YES you are correct,its well hidden away & didnt even see it with head in glove box hole.
The item found is as shown below.
A couple of question if i may.
The 2 updated box's from this one is RC / AS
1,
Can either of the below be bought,depending on availability etc & work.
CL DL RC or CL DL RC AS
Currently when doors are unlocked with the key,indicators just glow.
Using the box with AS would you then get the beep beep like on my MK6 transit ?
2,
By unplugging/pluggin in the new box does anything happen with radio code etc ?
