hi, the old van failed the MOT
could somebody tell me if the catalytic exhaust section of exhaust will slide out without having to remove anything else on a 2003 model
was under having a look & looks a bit tight,
thanks for your help
Graham Taylor wrote:Yes, undo bolts at manifold then undo from main section underneath
trixyben wrote:is that section the exact same in the mk1 focus does anyone know?
Graham Taylor wrote:trixyben wrote:is that section the exact same in the mk1 focus does anyone know?
Try googling Mk1 Focus cat and compare with the Connect. Engines are basically the same but exhaust isnt, not sure about the cat but I'd be surprised if it was.
