hi,
when i am overtaking my powertrain light comes on. the van struggles to hit high 2000rpm. at the next set of lights if i turn the engine off and on again the light goes away and all is fine. usually until i go to overtake someone again.
what i was wondering is, will the fault code stay in the memory if i take it to get put on a diagnostics or does the light have to be on for that.
also i have read that this could be a dirty egr valve problem, would it be worth taking out and cleaning before i do anything else.
i figure it cant be a bad mechanical problem as the light would stay on all the time, that it just has to be a faulty sensor. would this make sense
08 ford connect
75ps
lwb
engine 1.8l duratorq tcd fgt - lynx
