Hi,
I'm a new transit owner (2015) and very pleased with it but I'm hoping someone can help me with a couple of things:
Water in footwell -
There was water under floor lining and the foam is soaking, Ford have sealed the problem for me but are going to call me as they are seeking permission from ford to replace the floor lining. Has anyone else had this problem, and should I worry?
Secondly, please see attached photo - the drivers wiper arm doesn't seem to return all the way down when not in use, is this how it should be or should I give Ford a shout again? All seems to be connected up OK.
THANK YOU
