Help, timing chain case stuck
Postby Piglet » Wed May 04, 2016 10:55 pm
Help!
Please pretty please,
The bit Ford call '6K011 1131928 Housing Assy - Timing '
That's the big casting that holds the timing chain.
I've got it all free and moving BUT something is holding it at the bottom.
There isn't a bolt from inside the sump is there?
Piglet
Re: Help, timing chain case stuck
Postby Boghopper » Fri Dec 01, 2017 3:33 pm
Oh, man. It's like bloody Déjà vu! At least by finding this thread I am now relieved that it isn't specific to me. How did you remove the bloody thing in the end, may I ask? I have been at it for two hours so far, how long where you messing with these obstinate things?
Boghopper
Postby mk2dk » Fri Dec 01, 2017 8:07 pm
Don't know if these pics are any good, I don't remember any hidden bolts.
mk2dk
mk2dk
Postby Boghopper » Fri Dec 01, 2017 8:36 pm
Well, you see you have the engine mount bracket off, that's the four bolts that compress the timing case gasket against the block. When I took mine out water started oozing from them.
I have tried everything with this rear case and it won't budge. I have nothing left that I can remove that would help me get it off. I cannot believe a gasket can be gripping it like this.
Boghopper
Postby Piglet » Fri Dec 01, 2017 10:08 pm
Jeez my memory is awful I don't remember writing that.
I'm sure there is 1 or 2 bolts from under through the lower casing. pulling it down onto the rubber seal.
Piglet
