Hei all,
Wet belt killed my R3PA 2010 @ 169000 km. Need to know which engine series I can get the mechanic to find and dump in with out to much work other than programming the pump and injectors into the ecu. Also what kinda damage if any to the pump, injectors, ... Other than the valves and piston heads. Any help would be very helpful, kinda have to get home.
