chrisandmark wrote:Hi folks,clonking sound when changing gear usually 2nd gear when taking foot off clutch,today the gearbox mount was changed,the one that looks like a pork chop.the issue still remains,no significant play when you push engine back and forth,the mount on the left under water top up bottle looks ok too,could it be clutch?going to check drive shaft bolts now,back in a bit,thanks in advance for any advice.
