blue estate wrote:Turbo over/under boost doesn't throw up eml straight away but multiple codes do
brianj42 wrote:Update: And its a good news bad news situation:
After the mechanic changed the air intake and I did the throttle, all seemed ok, apart from one solitary limp mode over 4 days and 300 miles.
But then the thermostat housing blew a leak and it was in yesterday for replacement.
The mechanic replaced and mentioned that in order to get to the thermostat he had to remove all the fuel pipe system. One the way home within a mile ONE limp mode
Today, its in limp mode every 100 metres and theres a smell of diesel under the bonnet. Can't see any loose connections but the car is not driveable.
It is going back tomorrow for him to sort as we feel that something has gone wrong whilst removing the fuel system.
The TWO new codes for the limp mode are P0251 and P1211, which, from what I have read is fuel issues but could be one of a number of things.....But that these new codes should follow the removal of the fuel pipes is the main suspect......
Any thoughts ?
doebag wrote:Yes, faulty one only is fine.
That's not to say the others may play up sooner or later though.
