Hi to you all.
Can anyone shed any light on these mk1 2006 connect 1.8 tddi 75hp clocks as mine has just decide to go all limp and die.
I have tried the speed sensor on the box and changed all the fuses in the fuse box and even reset the clocks by unplugging them, checked wiring ect...
The clocks are
visteon
2T1F-10849-DH clocks with the single lcd screen and one black and one white plug on the rear.
So my question is ...
Can the dual screen lCD clocks fit my van with no troubles or do I need to buy the exact same clocks as I already have?? Also do I need to get anything coded with the new clocks ie does the immobiliser or anything run threw the clocks??
Any help would be greatly appreciated as I don't fancy doing a few speed cameras with no clocks
Cheers
