haveajiggle wrote:quick update ,had leak off test done and 2 injectors filled bottles slightly more than the other 2 ,took them out and gave them to a diesel guy to test and clean ,he did them and showed me they were working much better,vans still going into limp fooking dick mode really starting to hate this van ,back on scanner same codes came up ,went into live data thing and maf sensor didnt seem to do anything at all when van was revved up ... has anyone ever actually cured these tdci connects with these fault codes or do we just spend a load of hard earned on them then torch them ...rant over any help would b nice
P0622 Generator Field Terminal Circuit - ALTERNATOR
U1262 SCP (J1850) Communication Bus Fault
Injectors with excessive leak off require refurbishment (New internal parts etc) - Cleaning them will NOT solve the issue
As posted previously.....
Glow plug light flashing & engine going into limp mode. With following DTC's (error codes) stored.
P0251 Injection Pump Fuel Metering Control
P1211 Injector Control Pressure Higher/Lower Than Desired (engine running)
It will either be injector fault or fuel pump. Or in some cases both
Injector leak off test will confirm if injectors are at fault. - If 1 or 2 are faulty, it's best to replace all 4
Check diesel filter for swarf - If present, fuel pump has worn out.
Replacement fuel pump & injectors are required.
Above is a common problem effecting 2003-2006 Transit Connect 90ps TDCI's
P2291 Injector Control Pressure Too Low - Engine Cranking - Possibly blocked fuel filter.
Most cases when engine fails/difficult to start - worn out fuel pump.
See thread here viewtopic.php?f=54&t=163873&p=1391475&hilit=P1211#p1390651
