2015 Connect Limited Auto Lock.
Postby Tdci_boy » Thu Nov 17, 2016 7:40 pm
Hi gang, silly question time perhaps, my van as do many I'm sure has a button on the dash to lock the van, my old Transit would lock when pulling away or at low speed, does anyone know if this feature can be programed by me, else does it need to go into Ford to be done ?
Transit connect 2015 240T1150 Limited L2 plus nearly every toy on the list, twin side loading doors, fully kitted out with Sortimo racking, always loaded to capacity & averages 45mpg :D
Tdci_boy
GLX Posse
Re: 2015 Connect Limited Auto Lock.
Postby Jon James » Fri Feb 09, 2018 6:07 pm
Hi there,
Did you have any luck? I also have the connect limited 65 plate and would like to activate this locking, but I cant find it in the menu. Is it available on this model?
Thanks,
Jon
Jon James
Postby Tdci_boy » Sun Feb 18, 2018 10:52 pm
Hi John,
It’s definitely not in the menus unfortunately :-( I was in Ford having my stupid sidelights turned off I should have asked
Tdci_boy
GLX Posse
Postby Jon James » Tue Mar 20, 2018 2:18 pm
Hi Finally got it done at a ford dealer, they just installed the soft wear...............price kerching! £65
Jon James
Postby chelsea » Sun Apr 15, 2018 11:36 am
Enabling or Disabling Auto lock andAuto unlockNote:
An authorized dealer or you can carryout this procedure.
To enable or disable these features,
do the following:
1.Switch the ignition on.
2. Press the power door unlock button three times.
3.Switch the ignition off.
4.Press the power door unlock button three times.
5.Switch the ignition on.
The horn will chirp indicating your vehicle is in programming mode.Auto lock:
Press the power door lock button for less than one second and release.
The horn will chirp once if disabled or twice (one short and one long chirp) if enabled
chelsea
Postby Mike » Mon Apr 16, 2018 8:17 pm
I thought this ^^^^^^ only worked if the feature was already enabled?
Mike
Wind up merchant!
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot]
