59 plate lwb connect. Approx 145000 miles. Van will not start, will turn over but not start,
Garage says problem will fuel pressure on low side. They say fault codes are showing for all four injectors and fuel pump, but that could be because there is no fuel getting to the pump or for the injectors to open/work. They removed fuel filter and only half full. They also had it running via a fuel bowser set up feeding the pump.
Any thoughts ??
TIA
