1.8tddi 2003 connect won't start
Postby ShaneP32 » Wed Jan 11, 2017 9:46 pm
My connect 1.8 Tddi just cut out driving along tried it with easy start and it start and stops got diesel coming from the injectors. It hasn't had a diesel filter on since I had it sounds like it want to start it's done 219k 2003.
ShaneP32
Re: 1.8tddi 2003 connect won't start
Postby paul2012 » Thu Jan 12, 2017 3:18 am
Welcome to the forum. :D
I would get TDC's read 1st (error codes).
TDDI's are prone for fuel pump failures (EDC bolted to top of pump)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby ShaneP32 » Thu Jan 12, 2017 8:17 am
Do you mean put a code reader on and see what codes come up lol?
ShaneP32
Postby ShaneP32 » Fri Jan 13, 2017 8:15 am
paul2012 wrote:Welcome to the forum. :D
What do you mean lol?
ShaneP32
Postby paul2012 » Sun Jan 15, 2017 9:24 pm
ShaneP32 wrote:Do you mean put a code reader on and see what codes come up lol?
Yes get code reader. NOT a OBDII one as 2000-2006 Connects are NOT OBDII compliant.
F-Super 2 here will work
http://www.ebay.co.uk/itm/F-interface-S ... Sw~OdVZIQY
paul2012
Postby ShaneP32 » Fri Jan 20, 2017 4:09 pm
Hi I found the problem it was the EDC on top of the fuel pump had that fitted and programmed and it started fine it also had a new diesel filter it was running fine all day just when I when to start it the next morning it wouldn't start then managed to start it after cranking the injectors and there was diesel up and leaving the ignition of for about a minute the turn the key and it starts after about 3-4 turns and Thort it was fine then it done the same the next morning just wondering if anyone else has had this problem it's fine when it's started just when the engine is getting cold just wondering if it could be something to do with the fuel filter being fitted Much help would be appropriated
ShaneP32
Postby phil drew » Fri Jan 20, 2017 4:26 pm
sounds like could be drawing air possibly around filter area if it was ok before filter changed
phil drew
Postby ShaneP32 » Fri Jan 20, 2017 4:41 pm
The van was running fine then it just died and found out it the the EDC so change the EDC and the filter at the same time
ShaneP32
